Display options
Status:... shows the current bluetooth status.
- Unavailable - no bluetooth stick is plugged in the MOD
- Unsupported - the bluetooth version of the stick in use is too old (needs >= bluetooth 3)
- Starting... - bluetooth service is starting
- Disconnected - bluetooth active, no devices connected and not discoverable
- Discoverable - bluetooth active, discoverable (and perhaps with devices connected)
- Connected - bluetooth active, at least 1 device connected but not discoverable
Name:... shows the bluetooth device name for your specific MOD.
Usually includes batch and serial number as suffix for uniqueness.
Address:... shows the MAC address of the current bluetooth stick in the MOD.
Connecting using bluetooth
Windows
1. Turn on the MOD Duo and plug a Bluetooth USB stick into it
2. Right-click the Windows bluetooth icon and click on "Join a Personal Area Network"
3. Open the MOD controller menu (by holding the left knob down), go to the bluetooth menu and enable discovery.
Mac OS
3. Click the "Pair" button
There are quite a few different bluetooth manager applications under Linux, so we won't cover them all here.
1. Turn on the MOD Duo and plug a Bluetooth USB stick into it 2. Wait for it to boot 3. Open the MOD controller menu (by holding the left knob down), go to the bluetooth menu and enable discovery. 4. Use your bluetooth manager application to look for bluetooth devices 5. Select the MOD Duo and connect to it 6. Join the bluetooth network created by the MOD Duo 7. That's it. Open your browser and go to http://192.168.50.1/
