Display options
Status:... shows the current bluetooth status.
- Unavailable - no bluetooth stick is plugged in the MOD
- Unsupported - the bluetooth version of the stick in use is too old (needs >= bluetooth 3)
- Starting... - bluetooth service is starting
- Disconnected - bluetooth active, no devices connected and not discoverable
- Discoverable - bluetooth active, discoverable (and perhaps with devices connected)
- Connected - bluetooth active, at least 1 device connected but not discoverable
Name:... shows the bluetooth device name for your specific MOD.
Usually includes batch and serial number as suffix for uniqueness.
Address:... shows the MAC address of the current bluetooth stick in the MOD.
Connecting using bluetooth
Windows
1. Turn on the MOD Duo and plug a Bluetooth USB stick on it
2. Right-click the Windows bluetooth icon and click on "Join a Personal Area Network"
3. Open the MOD controller menu (by holding the left knob down), go to the bluetooth menu and enable discovery.
5. Select your MOD Duo from the list and click continue.
7. Select the MOD Duo icon and click '...' under '...'
9. That's it. Open your browser and go to http://192.168.50.1
Mac OS
3. Click the "Pair" button
Pair devices
Creating the network
- sudo dhclient bnep0
