Display options
Status:... shows the current bluetooth status.
- Unavailable - no bluetooth stick is plugged in the MOD
- Unsupported - the bluetooth version of the stick in use is too old (needs >= bluetooth 3)
- Starting... - bluetooth service is starting
- Disconnected - bluetooth active, no devices connected and not discoverable
- Discoverable - bluetooth active, discoverable (and perhaps with devices connected)
- Connected - bluetooth active, at least 1 device connected but not discoverable
Name:... shows the bluetooth device name for your specific MOD.
Usually includes batch and serial number as suffix for uniqueness.
Address:... shows the MAC address of the current bluetooth stick in the MOD.
Connecting using bluetooth
Windows 7
2. From the Control Panel, go to "Devices and Printers". In this window, click in "Add device" button, located at the top left window corner.
3. Wait for your MOD to appear as one of the available devices, according to the picture below.
4. Select the MOD device and click in "Next"
5. In case a PIN is requested, use 1234. Depending on the Bluetooth version, the PIN won't be necessary.
6. Wait for the pairing process to finish and then close the window.
6. Back to the "Devices and printers" screen, right click on MOD and select "Connect using" > "Access point", according to the picture below.
7. That's it. Open Google Chrome and go to http://192.168.50.1
Mac OS
3. Click the "Pair" button
Pair devices
Creating the network
- sudo dhclient bnep0
