Display options
'Enable discovery' will turn on discovery mode.
'Status: ...' shows the current bluetooth status.
- Unavailable
- Unsupported
- Starting...
- Disconnected
- Discoverable
- Connected
'Name: ...' shows the bluetooth device name for your specific MOD.
It includes batch and serial number as suffix for uniqueness.
You can customize this name by creating a file '/data/bluetooth/name' inside the MOD. Its contents define the name.
'Address: ...' shows the bluetooth dongle MAC address.
Connecting using bluetooth
Windows 7
2. From the Control Panel, go to "Devices and Printers". In this window, click in "Add device" button, located at the top left window corner.
3. Wait for your MOD to appear as one of the available devices, according to the picture below.
4. Select the MOD device and click in "Next"
5. In case a PIN is requested, use 1234. Depending on the Bluetooth version, the PIN won't be necessary.
6. Wait for the pairing process to finish and then close the window.
6. Back to the "Devices and printers" screen, right click on MOD and select "Connect using" > "Access point", according to the picture below.
7. That's it. Open Google Chrome and go to http://192.168.50.1
Mac OS
3. Click the "Pair" button
Pair devices
Creating the network
- sudo dhclient bnep0
