Troubleshooting
Windows 7 or Windows 10 64-bit
1. Make Windows look for drivers, and when given the option select "Browse your PC"
2. Click 'Pick from a list of devices in my computer'
3. Select 'Network Adapters' and press 'Next'
4. Select 'Microsoft Corporation'
5. Select 'Remote NDIS Compatible device'
Windows 10 (32-bit)
If using the 32bit version of Windows 10, the 'Microsoft Corporation' does not appear as an option when browsing for drivers.
In this case we need to download and install a custom driver.
1. Download http://web1.moddevices.com/shared/mod-duo-ethernet.zip, and extract the contents 2. Make Windows look for drivers, and when given the option select "Browse my computer for driver software" 3. Click 'Pick from a list of devices in my computer' 4. Click the 'Have Disk...' button 5. Click the 'Browse' button 6. Navigate to where you extracted the file you downloaded before, and make it open the 'mod-duo-ethernet' file 7. Click 'OK' 8. You should now see 'MOD Duo Ethernet' listed. Select it and press 'Next'
Site LOCAL
Accept from LOCAL
