In this page you find instructions to connect your computer to the MOD using bluetooth. Please note that the MOD unit does not include a bluetooth chip inside, you have to plug a bluetooth usb dongle on MOD for this to work. Also, bluetooth version 3 or higher is required.
Mac OS
3. Click the "Pair" button
4. In case a PIN is requested, use 1234. Depending on the Bluetooth version, the PIN won't be necessary.
Windows 7
2. From the Control Panel, go to "Devices and Printers". In this window, click in "Add device" button, located at the top left window corner.
3. Wait for your MOD to appear as one of the available devices, according to the picture below.
4. Select the MOD device and click in "Next"
5. In case a PIN is requested, use 1234. Depending on the Bluetooth version, the PIN won't be necessary.
6. Wait for the pairing process to finish and then close the window.
6. Back to the "Devices and printers" screen, right click on MOD and select "Connect using" > "Access point", according to the picture below.
7. That's it. Open Google Chrome and go to http://192.168.50.1
Pair devices
Creating the network
- sudo dhclient bnep0
