MOD Duo
Development
We launched a crowd funding kickstarter campaign to raise funds to produce the MOD Duo.
Read more in our website.
Technical specs
- width: 180 mm
- length: 160 mm
- height: 74.7 mm
Audio
- 2 independent inputs:
- TS connectors
- Digital input impedance selector
- line 1 MΩ
- microphone 3 kΩ
- instrument 75 kΩ
- color LED
- Programmable Gain Amplifier: ± 12 dB Gain, 0.5 dB step plus a 32 dB gain stage for microphone
- 2 independent outputs:
- TRS connectors (balanced)
- color LED
- Volume Control: 0 to -127 dB, 0.5dB step
- Headphone output:
- TRS connector
Neutrik® connectors, True Bypass circuit
- MIDI IN connector - DIN 5 pins - for musical instruments and controllers
USB
- USB Bluetooth
- USB Wifi
- USB MIDI
- USB Ethernet Adaptor
- USB Audio 2.0
Controllers
- 2 knobs with LCD screen
Processors
- A20 CPU:
- Dual Core ARM A7 1.0GHz
- 1 GB RAM
- 4 GB Flash Storage
- Audio CODEC:
- Manufacturer: Cirrus Logic
- DAC: 104dB dynamic range, -90dB THD+N
- ADC: 104dB dynamic range, -95dB THD+N
- 24 bit / 48 kHz AD/DA
Peripherals
Software
Utilization
See the Quick Start Guide to begin using the MOD Duo.
Selecting a pedalboard
- Long press the right knob to access the previously saved pedalboards banks
- Turn the right knob to select one of the banks and press to select
- Turn the right knob to select one of the pedalboards and press to select
- Long press the right knob to exit the menu and start using the pedalboards
Long press the left knob, turn to chose the item in the menu (clockwise to go down and counterclockwise to go up) and press to select it.
Volume and gains
- Input 1
- Input 2
- Output 1
- Output 2
Each input and output gain can be set using the following menu.
- Stage: turn the left knob and press it to select the input gain
- Low
- Mid
- High
- Fine adjust: turn the left knob to adjust the input gain from -12dB to 12dB (default 0dB)
- Volume: turn the left knob to adjust the headphone gain from -33dB to 12dB (default -15dB)
- Direct monitoring: press the left knob to switch the headphone direct monitoring
- Services: press the left knob to see the activated services
- Versions: press the left knob to see the hexadecimal versions of
- system
- controller
System upgrade
- Press the left knob to start the system upgrade process
- Turn the left knob to chose between confirming (YES) or canceling (NO)
- To confirm, press the left knob while holding the left foot switch
- Wait while the MOD Duo enter in restore mode
- Connect the MOD to your PC if not done yet, and wait for a new mass storage drive to appear
- Download the last release file from download.moddevices.com
- Copy the modduo.tar file into the new drive, and use your OS option to safely remove the drive.
At this point the MOD Duo will start auto-updating. DO NOT TURN IT OFF!
Please wait until the update finishes. The MOD will auto-reboot when the process is complete. User data will remain untouched.
